49 jda
Gene Johnson
03-18-2008 12:25:35
I have a starter problem. voltage is getting to lug behind he flywheel. Looks like the starter need to come out. My book say nothing about starter removal.Do I start by removing the square plate at bottom with 4 bolts? If so what do I do then?
johns48jdb
03-19-2008 05:30:41
 Re: 49 jda in reply to Gene Johnson, 03-18-2008 12:25:35
no! but do disconnect the battery cable first from the battery as stated. not much room for two guys under there until your ready to pull the last bolt. another hand on the starter is insurance against dropping it in your face. don't ask.
jdhbag
03-18-2008 14:20:34
Flywheel doesnt have to come off but flywheel cover will have to. Then remove starter rod and wires to starter. There are 3 bolts holding the starter to the housing. They are behind the flywheel aroung the starter bendix housing. Then remove starter and it is heavy as John T said. Not that much of a job, I've just done 2 B's and an A.
Jim in ok
03-18-2008 14:13:54
no you do not have to remove flywheel just the flywheel cover. now installing the starter the lever on starter will interfere with you. I used baling wire to work lever going back in
gene Johnson
03-18-2008 21:29:42
 Re: 49 jda in reply to Jim in ok, 03-18-2008 14:13:54
Jim, where in Ok. do you live in ? I live near Ramona, Ok. between Tujsa and Bartelsville
John T
03-18-2008 12:59:40
Gene, You may indeed have a starter problem buttttt tttt just because voltage is at the switch post dont necessarily mean you have the necessary amps due to a bad connection or bad battery or bad ground etc elsewhere. To be safe Id first remove n clean n wire brush n reattach each n every battery n starter n ground connection and if you happen to ground to a thin wimpy or rusty seat or battery box you may wanna try a better ground conenction. If the battery n connections n grounds are alllll llll okay then you may have a starter switch or starter post (under the saddle switch) problem but you need to remove n inspect for that. BE SURE N REMOVE THE BATTERY CABLE before you work under there n when that starter comes free shes real heavy ya know.
John T
donwisc
03-18-2008 12:45:27
You are on the right track however once you take the cover off you may not like what you see. Everything is in close quarters and if you can fix your problem and possibly not remove the starter, DO IT.
Having said that the starter will come out and go back in but not without using all the swear words in your vocabulary.
Gene Johnson
03-18-2008 13:15:13
 Re: 49 jda in reply to donwisc, 03-18-2008 12:45:27
Is it neccessary to remove the flywheel to get cable and starter linkage loose?
