335 Baler
tomtractor61
03-17-2008 17:37:06
I just bought a 335 Round Baler. Anyone out there with any advice or experience with them, input would be appreciated. Anything to watch out for on them, or suggestions?
almrm
03-19-2008 11:22:58
 Re: 335 Baler in reply to tomtractor61, 03-17-2008 17:37:06
I have not had a 335 but I had a 430 and now a 447. The 335 and 447 are both 4x4 balers. The 447 is just a later model. My advice is that you inspect the belt pins every year. I change mine every 2 years. The pins are cheap. When they wear and fail, they will rip out the lacing. Lacings are also fairly low cost, but you don't need the delay of fixing them when there is hay ready to bale. You also do not want your belts to keep getting shorter as you repair them. I learned this maintenence on my 430 and have made several thousand bales with my 447 and have not relaced a belt yet. A damaged pin is almost always the cause of a belt lacing failure.
Mark
turklilley
03-17-2008 18:15:33
I like mine, good little baler. I always set the pickup too low, I know better, then the belt slips.
