630 JD transmission problem
Larry Wilson
03-16-2008 18:35:20
Sometimes when I select a gear on the left side of the shifter (R, 1st, 4th, 2nd) it will seem to go in ok, but when I engage the clutch, the tractor won't move. I then have to choose a gear on the right side and engage it a time or two, go back to the left side, and it will be ok.
Any help would be much appreceiated.
wilamayb
03-16-2008 20:04:02
 Re: 630 JD transmission problem in reply to Larry Wilson, 03-16-2008 18:35:20
This happens with the conjunction of worn shift parts. What is happening is that when you shift to the left side you are moving the range shifter (overdrive shifter) This shifter will be in the very front if you remove the shift quadrant.
Many times this can be fixed by making sure your shifter is in tip top shape. You may want to remove your shift quadrant, Then replace worn shifter parts. These parts are avialable from Deere at a fairly reasonable price. Just take up all the slack you can by replacing the fulcrum ball, making sure you have snap rings that stay in their groove, etc.. etc..
A multitude of worn parts can be ignored by having a tight shifter.
You will know when it is right. The shifter will not go all the way over to the left without rolling the clutch a little. This is aligning the teeth on the gear so they can mesh.
Larry Wilson
03-17-2008 16:21:38
 Re: 630 JD transmission problem in reply to wilamayb, 03-16-2008 20:04:02
Thank you very much for this information. I will study this and try to fix this myself.
Zap
03-16-2008 19:43:09
It sounds like either the shifter rods are worn or they may be out of adjustment. Either way you have to do some work. First I would start by taking the shifter housing off and looking inside the transmittion. Look at the shifters where the shifter ball goes to see if it is worn. If it is you will have to remover the shifters. If it is just out of adjustment you will have to get a book or adjust the so the gears aligne. If you take out the shifters you will have to remove the flywheel and the side cover on the flywheel side. You can weld the groove on the shifter by using a nichel rod and reinstall and adjust the shifters. I adusted mine by lining up the gears when in the detent on the shifter rod.The adjustment is under the cover under the flywheel.
Larry Wilson
03-17-2008 16:23:24
 Re: 630 JD transmission problem in reply to Zap, 03-16-2008 19:43:09
