1970 2520D making engine oil
SWMO Chris
03-16-2008 17:52:41
This has me baffled. My 1970 2520 diesel is making oil. I cannot figure out why it is doing this. Could the diaphram in the transfer pump be leaking? It starts fine everytime. I do have a small diesel leak by the wire going into the injection pump. Any ideas?
jdemaris
03-17-2008 07:26:30
 Re: 1970 2520D making engine oil in reply to SWMO Chris, 03-16-2008 17:52:41
Does the wire attache to a small stud on top of the pump with a nut on it - or does attach with a push-on connector on side of the pump?
I ask because there's a big difference - and most 1970 2520s had the model CB injection pump with the push-on connector. If so, there isn't any brass bushing as mentioned, and there are no shaft umbrella seals.
I can give you advice on how to fix, but first tell us what you have.
2520 can have the following CB pumps:
CBC431-4AL OR CBC431-16AL
Or the following JDB pumps:
JDB431AL2473 or JDB431AL2730
Jake Winn
03-16-2008 18:09:16
The transfer pump is the cheapest place to start. Its usually that or the seals on the injection pump drive shaft. Usually the brass bushing has some wear in it or a seal is cracked.
msb
03-16-2008 18:30:34
 Re: 1970 2520D making engine oil in reply to Jake Winn, 03-16-2008 18:09:16
Pull the transfer pump, If the diaphram is leaking the backside of the pump should be washed clean.
