Buddy Seat
Kris A NC
03-16-2008 15:21:24
I have seen the ad in Green Magazine, but I would like to find one for a little cheaper if I could. I want to mount it on a "51 B for a tractor ride coming up in April. Any info or opinions welcomed. Thanks!
Kris A NC
CalJim
03-17-2008 21:45:23
 Re: Buddy Seat in reply to Kris A NC, 03-16-2008 15:21:24
We were really disapointed when we put together the buddy seat we got from the ad in the magazine. We have an unstyled tractor with the seat channel and it felt weak and flimsy with 2 people in it. I had to beef it up before we felt comfortable in it. That being said, I think it would work much better with a battery box seat, it would be supported better. CalJim
mikicic
03-17-2008 12:59:24
I made my own out of an old seat frame. I got some 1" angle iron, welded it together, the took the seat rails off the old seat and welded them to the newly fabricated frame, make sure it will fit the battery box. Took the arm rests off the old frame and found a piece of pipe that would connect the two sides. welded them to the fabricated frame. Then cut a piece of plywood smaller than the opening, and went to an opholstery shop to have a cover made with foam.
wilamayb
03-16-2008 17:53:39
I'm afraid that the repro of the demonstrator seat is about as cheap as you will find. You might make yourself something with two seat frames??
If you think the repro is expensive just price and original! Thats if you can find one!
Kris A NC
03-17-2008 06:51:06
 Re: Buddy Seat in reply to wilamayb, 03-16-2008 17:53:39
Thanks for the info. I appreciate it!
Kris A NC
