52 -B Water problem.
Roger Cary
03-16-2008 14:15:00
52 model B-- Has been setting up since last fall & when trying to get her back up & running, When cranking over water runs out below the flywheel cover @ or around the oil filter area. She has been outside, but both exhaust & air stack were completly covered. What am I looking at? After I continued to crank it over it finally quit. Still need to tune up & check plugs, pts.mag etc. Help Please.
Roger Cary
03-16-2008 17:18:37
 Re: 52 -B Water problem. in reply to Roger Cary, 03-16-2008 14:15:00
Guess I will change fluids & filters, need to anyway,before I try to get her started for spring. With new plugs pts. etc. will see if she runs & hope block isn't cracked. Thanks guys
Lee B
03-16-2008 15:58:25
You are probably looking a standing water puddle blown into the flywheel as snow and retained by an odd shape of the flywheel itself. Not harmful in any way so nothing needs to be done?
You didn't say how much water, so this wouldn't hold past a couple of cups. Anything more would be something else I would think.
Roger Cary
03-16-2008 15:43:17
Yes there is antifreez in radiator & it is still full.?????
jd b puller
03-16-2008 15:31:37
 Re: 52 -B Water problem. in reply to TSinMD, 03-16-2008 14:15:00
Roger, did you have antifreeze in the radiator? Was the water in the CC antifreeze or water?
d. coleman
03-16-2008 15:26:20
what about a cracked block? id check water in radiator. was there antifreeze in water running out? did you have antifreeze in radiator during winter?
rusty wheel
03-16-2008 14:56:53
I'd change the oil filter and all the fluids. Oil is cheap compared to other parts and a lot less work and also less time consuming..... .rw
