4020 selective control valve
Bob Bancroft
03-16-2008 13:13:01
I have a good one I'll part with. I've had a major education trying to repair a bad one (internal leak) ended up replacing both with newer type.
jdemaris
03-16-2008 13:32:40
 Re: 4020 selective control valve in reply to Bob Bancroft, 03-16-2008 13:13:01
What's the difference? I had to fix many of them when I worked for Deere, and as I recall they're all pretty much the same inside regardless of where they are mounted. Valve spools, seats, and adjustment screws. Old spools had metal seat-surfaces, and replacements have a soft coating.
Bob Bancroft
03-16-2008 13:59:21
 Re: 4020 selective control valve in reply to jdemaris, 03-16-2008 13:32:40
It's been a while since I've been inside one as I have given up and had people with more experience than myself doing the work. I put housings on the 4020 off the 30 series utility tractors, (which were also used on later 5020's) I believe the spools, etc. or more like those in the SCV's on later 4020-30-40-series(down on the back of tractor)The end cover has four 3/8" bolts with a flow control knob. The original old style 4020 SCV I believe has different spools. The end cover has six 5/16" bolts with a flow control set screw and a detent set screw.
jdemaris
03-16-2008 15:23:48
 Re: 4020 selective control valve in reply to Bob Bancroft, 03-16-2008 13:59:21
Yes, that much I'm aware of - but the theory of operation is the same with them all. I don't recall any one of them being better or worse than the other. The spools were the #1 problem, and the design got changed many times. I'm pretty sure those changes are retroactive when putting in new parts. But . . . I haven't worked on one in at least 10 years - and haven't worked for a Deere dealer since 1991. I'm clue-less as to what the new tractors have now.
Bob Bancroft
03-16-2008 13:15:36
sorry-forgot-old style(up under hood)
msb
03-16-2008 18:36:57
 Re: 4020 selective control valve in reply to Bob Bancroft, 03-16-2008 13:15:36
Did anyone try grinding the valve seats? $200 for the kit.Just bought a new one. Hook up an air hose to see where it was leaking? Try adjusting it while charged with air ?
