J.D. three point Ballast Box
lekander1020
03-16-2008 03:23:55
Yesterday I picked up a good used ballast box. Now I'm wondering whats the best stuff to put in it for maximum weight? It's only about 2' square. I'm planning on putting this behind the 1020.
fixerupper
03-16-2008 17:28:29
 Re: J.D. three point Ballast Box in reply to lekander1020, 03-16-2008 03:23:55
I have a two foot square concrete weight on the 3PH of the loader tractor. I weighed it on the neighbor's platform scale and it weighed 1300 LB. Don't know if the scale was real accurate so that's a ballpark figure. Jim
Mike M
03-16-2008 14:07:00
Go to your local tire shops and see how much you can buy the scrap lead wheel weights for. This will give you the most weight in any easy to handle form. I have a section of VERY HEAVY DUTY chain about 150 ft. and weighs around 600 lbs. I can lift up a few feet at a time and coil it into one of those boxes.
RayP(MI)
03-16-2008 17:48:32
 Re: J.D. three point Ballast Box in reply to Mike M, 03-16-2008 14:07:00
Scrap lead is getting pretty precious nowdays. Sand would be a good ballast. Just be sure it doesn't get waterlogged, and freeze.
buickanddeere
03-16-2008 11:04:36
Cast individual concrete blocks you can toss in and out of the box.
johns48jdb
03-16-2008 08:11:11
make you some forms that will allow you to put 4 of the formed parts into the box. pour them full of concrete and put a bar in the top of each one to allow you to use a hoist to pick them up and set them over into the box. you can then adjust the load as needed depending on what you want to pick up. this way you still have your box clean and free so you can reuse it for just about anything. just adding any implement to the rear of the tractor should be enough balast any way, especailly a turning plow.
Armand Tatro
03-16-2008 05:38:14
We used slag from the cutting table in the machine shop and other metal shavings that we could find. This stuff is hard to dispose of as scrap yards don't want to mess with it. Work good for us. Armand
Wayne_H
03-16-2008 14:43:13
 Re: J.D. three point Ballast Box in reply to Armand Tatro, 03-16-2008 05:38:14
I filled mine up entirely with portland cement. I'm sure it's not as heavy as lead, but I seem to recall the cement was heavier than concrete. I'd almost be afraid if I filled it up all the way with lead I could not lift it!
Wayne
