46 B ran and then died
JD Gimpl
03-15-2008 18:40:01
Ok, it has been a long day. I started the B up as I always do and it ran for about 1-2 minutes and then just cut out and died. I have checked fuel and it seems I am not getting spark at the plugs. Is there a way to test the mag to see if I am getting spark out of it.
My thought was to check that first, plug wire second and plugs 3rd.
Any advice would be greatly appreciated.
Gimpl
DanL-Colorado B36320
03-16-2008 10:43:52
 Re: 46 B ran and then died in reply to PBrowning, 03-15-2008 18:40:01
johns48jdb said: (quoted from post at 06:26:50 03/16/08) my local lawn mower shop has a spark tester that you just plug in line. it has a clear tube on it to watch for fire jumping across. it may be a briggs part.
You mean like this?
http://www.matcotools.com/Catalog/toolcatalog.jsp?cattype=T&cat=2481&page=2&#40531
johns48jdb
03-16-2008 05:26:50
 Re: 46 B ran and then died in reply to JD Gimpl, 03-15-2008 18:40:01
rusty wheel
03-15-2008 19:30:29
You can pull the wire out of the mag, hold it close to the mag, crank the engine over and see if the spark jumps just like you do at the plug. If the spark doesn't jump from the mag to the wire, it's probably bad. The spark should jump to the wire even if the wire is broken inside the insulation. If the spark jumps to the wire, connect it back up and see if the spark jumps to the plug. If it doesn't then the wire is bad. If it does and the plug doesn't fire, the plug is probably bad. Hope this helps..... rw
