820 diff thrust washer
toolz
03-15-2008 17:55:41
I posted in the wanted ads, but thought someone here might help. I need a differential thrust washer for a 2-cyl 820. The part number is R68R, and it"s on page 45-8 in the parts book, #11 in the picture. I would take new or used, even worn badly, since I"m going to machine it thinner to make a spacer out of it. If anybody has one laying around, I"d appreciate a phone call, or email. Kevin at 217-377-3724. Thanks for your help.
Bob
03-15-2008 21:13:24
 Re: 820 diff thrust washer in reply to toolz, 03-15-2008 17:55:41
Since you will be modifying this washer to make a shim, have you checked sources such as McMaster-Carr for a washer or even steel shimstock that would fit your needs?
toolz
03-15-2008 23:43:43
 Re: 820 diff thrust washer in reply to Bob, 03-15-2008 21:13:24
Bob- I checked with the local bearing shop (Motion Industries), and they were unable to find a suitable spacer. The outside diameter was the problem. I can make one, or have one made, but I was hoping it would be easier to find a thrust washer, and it would be the proper hardness also. We'll see what turns up. Thanks for the reply- Kevin
Bob
03-16-2008 07:18:32
 Re: 820 diff thrust washer in reply to toolz, 03-15-2008 23:43:43
Here's a link to a guy who had 2 in stock a couple of years ago, but there's NO contact information.
Perhaps he could be contacted through the website www.greencollectors.com?
toolz
03-16-2008 12:54:46
 Re: 820 diff thrust washer in reply to Bob, 03-16-2008 07:18:32
Thanks again, Bob. I posted over there, so maybe I'll get lucky. I appreciate the info. Kevin
