Almost there on B timing????
davebr
03-15-2008 13:04:44
Ok guys, This is on my hand start B with a new carb and new mag. I appreciate all the help. I now get spark on #1 at 9:00. I put the mag on a bench and hooked it to spark plus and turned the lug till I got spark on #1. The tractor is quietly back firing. Could I have this 180 off? I did try switching wires around. but nothing? I timed the tractor as per book. One thing I had to do to get the mag not to click while timing was I loosened the four screws on the mag and went from 3-1/2 marks to 2-1/2. I have read most everything everybody has mentioned? What am I missing. It is doing more than it was before so that is a good sign?
Thanks,
Dave
d. coleman
03-17-2008 17:33:20
 Re: Almost there on B timing???? in reply to davebr, 03-15-2008 13:04:44
make sure you are coming up on #1 "COMPRESSION" stroke and not #1 "EXHAUST" stroke. at this setting the slot in mag drive should be in horozontal position, make sure mag. rotor is pointing to #1 terman on rotor cap and install mag. on governor drive. this should get you pretty close. good luck, d.coleman
Lee B
03-16-2008 16:49:37
As everybody is trying to tell you, you do have it 180 degrees off. Swapping holes only fixes this on some mags and I'm not up to speed on which ones that trick will work on and which ones it won't. I would just pull the mag to rotate the cup 180 degrees and carefully engage the lugs again.
You should have the mag set for 35 degrees not 25. The trick to not having the mag "impulse" while you work on it is to only turn it backwards until ready to test/set the impulse aspects.
It should impulse and spark #1 plug at 3:00 o'clock position.
If you have further problems you should double check #1 intake valve opening as per flywheel mark to ensure the flywheel is attached on the proper keyway and then ensure that at #1 TDC (impulse mark), the governor drive slot for the mag is horizontal indicating proper internal gear timing.
The governor can be timed without removal or even loosening of the governor case. It's done by removal of the mag and bearing cover on opposite side to disengage and rotate the gears to proper engagement, pretty easy if you've done it once before. If I remember correctly this has to be done not at TDC but backed up from there 30 to 40 degrees such that the governor weights can clear some internal dohickey that is in the way at TDC.
jdal
03-16-2008 08:19:52
The LH impulse mark on flywheel lines up at 3:00 to a mark on the maincase. Double check that the flywheel is on correctly, I had similar problem with an H, the crank had two marks and I aligned the flywheel with the wrong one.
Mike M
03-15-2008 14:30:44
The flywheel side is # 1 and your timing marks for it should line up at 3:00 at the same time the mag clicks. # 1 wire hole on the mag is the top one on XH and C model mags before mounting the mag you hook a wire into the top hole and turn the mag until you get that hole to spark more than likely it will turn past some so back it up until it is horz. like this - - then mount it on when # 1 cyl. is at TDC on compression and your marks lined up. Look into the spark plug hole and look for the piston and verify it is on TDC and your fylwheel isn't possibly on wrong.
davebr
03-15-2008 14:14:16
#2 sparks on 3:00, #1 at 9;00. I did try to switch wires but nothing?
GeorgiaHayFarmer
03-16-2008 04:29:30
 Re: Almost there on B timing???? in reply to davebr, 03-15-2008 14:14:16
#1 sparks at 3:00
