B Questions
patsdeere
03-15-2008 12:58:43
I have 2 questions that I need some help with.
The first is that I have a B that smokes horribly out of the crankcase vent tube. I checked the oil and it was full up to the filler hole. Any ideas on what it might be?
Second is that another B seems to backfire every couple of minutes. I am guess that the timing is off and was wondering which way I should rotate the mag so that it doesn't backfire. It doesn't happen every fire, but every 9-10th fire it burps. If it isn't the mag, what else should I be looking at? It doesn't matter if it is under load or idle.
Thanks.
d. coleman
03-15-2008 16:29:20
 Re: B Questions in reply to patsdeere, 03-15-2008 12:58:43
check crankcase vent pump at end of fan shaft for clogged vent tube or broken vanes. just my thought.
Paul from MI
03-15-2008 16:26:59
Don't know for sure what you are talking about hte oil level. Oil should just drip from the oil level test cock on the side of the crankcase. If it's fuller than that there's a good chance your oils is about half gas from not shutting off hte fuel at the tank when the engine was stopped. If it runs out in a stream from the test cock, CHANGE IT NOW!! As far as ignition timing Duane Larsen has an excellent method of really setting timing spot on. Check the archives for it, it's very detailed.
Paul
