2130 front wheel assist??
oldironjunkie
03-15-2008 06:56:38
I bought a 2130 that is supposed to have front wheel assist. It doesn"t work. How is it supposed to work? There are a bunch of wires behind the radiator that are not connected. Does anyone have a wiring diagram that could help me out?
buickanddeere
03-16-2008 11:13:51
 Re: 2130 front wheel assist?? in reply to oldironjunkie, 03-15-2008 06:56:38
Apparently they really did exist. There were even hydraulic assist 1030,1130,1630 & 1830's too. Mother Deere's part section has a full list for all those. You will also need the service manual.1-800-522-7448. Don't scrap the tractor or the system. You have a very rare bird there.
jdbenly
03-15-2008 20:09:01
I have worked on these front ends in the past. They are hydraulicly driven and electricly engaged. Phone me in the evening,1-807-826-2877.I am sure I can help you out.
oldironjunkie
03-15-2008 18:16:32
Sorry, I should have explained better. It has hydraulic front assist, that doesn't work. Electrical system is fine. It has started good all winter. I'm thinking that the disconnected wires might be my problem, but I'm not sure. Where does the pressure come from? Where are the actuator valves located? Can I hot wire it to see if it works? Thanks.
r john johnson
03-15-2008 09:57:28
I thought the 2130's had the hydraulic front wheel assist and it was electrically actuated. IIRC there was a post years back with a fellow who's front wheel assist would not work because his batteries were poor and couldn't provide the power needed to engage the hydraulic solenoid.
John
MSM
03-15-2008 08:00:29
If it is mechanical front,I would venture a quess and say the front axle is shot,especially if the tractor had a loader on it.Spider gears worn out or disintegrated,planetaries eaten up are common and expensive problems with them. If there is an electrical problem,the transmission defaults to 4x4,it takes current to disengage the front end not engage it.
