6--Volt Generator Conversion To 12 ??
AWB
03-15-2008 05:32:23
I want to keep my tractor looking original and install an electronic ignition module in it. My question is....Can my original 6 volt generator be converted to 12 volts without ruining it? If so, would like to know how to do it. Thanks, AWB
buickanddeere
03-16-2008 11:03:23
 Re: 6--Volt Generator Conversion To 12 ?? in reply to AWB, 03-15-2008 05:32:23
Just put a 12V regulator on it. May have to go down a size on the pulley.
36 coupe
03-19-2008 03:07:15
 Re: 6--Volt Generator Conversion To 12 ?? in reply to buickanddeere, 03-16-2008 11:03:23
I worked on a 55 chev that blew up a new 12 volt battery.I put an ammeter in the line and found a 60 amp charge rate at idle.The generator had been had been replaced with a 6 volt unit.Your post will cause much trouble for any one who trys it.A 12v generator fixed the problem.
NoID
03-16-2008 09:27:33
My mechanic claims the only requirements are a 12 volt battery and 12 volt bulbs in the light sockets. I tried it on a '47 A with the original cutout relay and switch. Works as new. BTW - He also dictated the parts and part numbers required for the engine and governor overhaul while dismantling the governor. Told me I should check the numbers before ordering - they were all correct. I don't even consider arguing with him - I hate to have to prove myself wrong.
Chuck730DSE
03-15-2008 05:43:30
Yes, it can be converted to 12 volts. I do not know how to do it, but any good generator shop can do it. I think they just change the guts of it. The outside stays the same so the correct police never know unless you tell them.
If you do not know fo a local shop, look in Green Magazine and Two Cylinder.
AWB
03-15-2008 05:53:42
 Re: 6--Volt Generator Conversion To 12 ?? in reply to Chuck730DSE, 03-15-2008 05:43:30
Chuck730DSE: Thank you for the information relating to the 12 volt generator conversion.
