4050 Engines
turklilley
03-14-2008 18:43:57
I have a 1983 4050. Someone told me the early ones had a 359 engine. Mine is MFD, power shift, with a 466 with Rossa Master pump. When did they change engines? Maybe mine was replaced?
SwedeDeere
03-16-2008 07:20:41
 Re: 4050 Engines in reply to turklilley, 03-14-2008 18:43:57
The european 4050 had a 466 Turbo, as i recall it. Am I right?
buickanddeere
03-16-2008 11:06:42
 Re: 4050 Engines in reply to SwedeDeere, 03-16-2008 07:20:41
Later tractors.Turbo on a 359 Dubuque engine. Early 4050 natural 466.
backwoodsfarm
03-15-2008 11:22:29
I think the 359 Turbo was used for better fuel economy without sacrificing power. I just recently purchased a JD 4040 European version with the 359 Turbo and it dynoed 103HP with 7500 hours on it.
buickanddeere
03-15-2008 15:55:43
 Re: 4050 Engines in reply to backwoodsfarm, 03-15-2008 11:22:29
4040 was built in Waterloo Iowa for both the export market & US/Canada. 4040 Book says a 90.8HP natural aspirated 404. No turbo Dubuque 359. There is an early and late 404 engine. The 4050 started production with a natural aspirated 466 then switched to the turbo 359.
wilamayb
03-16-2008 17:35:38
 Re: 4050 Engines in reply to buickanddeere, 03-15-2008 15:55:43
If you will check the parts catalog you will find that there is a European version of many of the later row crop tractors.
See look at that.. You learned something after all.
Dang kids these days!
backwoodsfarm
03-16-2008 17:11:09
My 4040 was built in Manheim Germany in December of 1980. 6 cylinder 359 turbo that tested 120HP at the engine and 105HP at the PTO. A fine gentleman who used to post often on this site helped me aquire the information from the Manheim factory itself. Only a few JD tractors had that engine, the late 4050, 3155, 3255 and the European version 4040 and 4040S.
matthies
03-15-2008 06:22:21
Serial number 5511-6509 had the 466 and 6510- had the 359.
960
03-14-2008 19:24:59
Early should have 466 non turboed with short air intake in front of muffler just like 4040. I do not know the change time but later had 359 turbo with tall air intake behind muffler.
