630 leaking
ccrock
03-14-2008 12:33:56
I have a 58 630 which has developed a hydraulic fluid leak. The fluid seems to becoming from above the cover that surrounds the pto, above that cover is the bracket for the top link. The fluid leak seems to be coming from behind that bracket. Is there anything behind that bracket that the fluid could be coming from? The top of the 3 point bracket is held by a rod which is held in place on both sides by the rear end housing, are there seals located where that rod and the housing meet?
SMinWi
03-14-2008 12:45:05
 Re: 630 leaking in reply to ccrock, 03-14-2008 12:33:56
That "rod" is the load control shaft, F 2899 R Yes it has a oil seal AR 20149 R It also has 2 bushings, AF 3099 R The oil seal and bushings are in the rockshaft and powershaft housing.
