It sounds like your friend has put in a lot of new parts. The price sounds pretty good to me. You have not said much about the engine and transmission however. I tend to think of the engine and transmission as being the "meat" of the machine and the other stuff necessary but ancillary. So, what has he done in regards to new pistons/rings? How do the cylinders look? Has he done anything with the head? Valves? Camshaft? How about the Crankshaft? Any new bearings (crankshaft etc). How do the gears look? Pitted? Any broken teeth? I think a little pitting is probably okay as the transmission uses hefty straight-cut gears but look for broken teeth and worn bearings. Also look for looseness in the gears and shifter arrangement (i.e. not shimmed properly). You mentioned the parts manual. Excellent source of information. There should also be a John Deere Service manual somewhere. The parts manual is great for showing the various parts and their arrangement, but the Service Manual tells you things like assembly order and torque. The 50 is a great little tractor. I would not worry about no power steering as they are pretty light up front and I've found them easy to steer as long as the machine is moving. Most 50's came with Powr-Trol lift (like yours) and most came with live PTO (PTO with its own clutch that runs off the engine and not the transmission). The lift is adequate but not as strong as a modern tractor. Like I said the front is pretty light so lifting a heavy blade or bush hog is okay but going over bumps may cause the front to bounce a bit until you drop the implement. One of the things I love about the 50 is that its got enough power to pull hard in the lower gears, and with the tricycle steering and separate braking you can turn it on a dime. Big enough to handle most jobs and small enough to be economical on fuel. Any chance your friend might help with the re-assembly? Are you pretty comfortable with a wrench? The tractor is not rocket science although on some things there is definitely a right and wrong way of doing things. You will find lots of help on this board. There are guys here (FIT, BuickandDeere, John T) who know lots more than I do. Does that answer your question? Didn't think it would but it does give you some things to consider. Best of luck, John 1953 Model 50
