In your opinion...
GeorgiaHayFarmer
03-13-2008 15:46:34
What makes a good starting gasoline 2 cylinder tractor? I have an old 1948 A that can sit outside through the coldest of weather and starts right up on the first couple of turns with no choke. I have had others that are as cantankerous as a donkey to get started.
higgins
03-14-2008 12:17:55
 Re: In your opinion... in reply to GeorgiaHayFarmer, 03-13-2008 15:46:34
It has to be related to keeping the air/fuel mixture good in the cylinders. Fresh gas at shut-down in the fall, no air leaks from there back thru carb to the oil bath and that in good shape, and good rings.
OTOH our G rarely was treated this nice and it always fired right away.
Sorno
03-14-2008 05:58:07
My 51 A starts on about a half turn to a full turn when really cold but I converted it to 12V. My 51 B with a 6V systems takes about 2-3 turns with the choke all they way open. I am sure the 12V systems makes a big difference.
John Van Valkenburgh
03-13-2008 19:50:56
I think good cold starting has a lot to do with the mixture setting and quality of the spark. If you tend to run the carb a little rich (as you would if you are using the tractor under heavy loads) then I'd think it would tend to be easier starting when cold.
If your tractors starts well cold even without choke, I'd say you are running a bit too rich.
My 50 wants full choke and usually fires within a couple of turns, but I have to go to half choke pretty quickly or it will fuss.
Some machines have an oil-pressure fuel shut-off. This keeps fuel from getting to the carb when the engine is stopped. Thats a good idea, but if the bowl dries out you may have to crank the engine a bit to develop oil pressure and open the valve. I've still got a manual fuel valve which I close at the end of the day.
John
1953 Model 50
1958johndeere620
03-13-2008 16:45:07
My 620 is the same way. If I choke it it will not start. Just pull throttle all the way back and crank it over. Damb thing fires on first turn over. I have to let it idle for a couple of minutes before I can give any throttle.
