4020D 24 Electrical Problem
Phil/PA
03-13-2008 12:54:17
Last time I ran my 1965 4020D it started fine but it has been sitting for awhile now. I went to start it and it won"t do anything. When I turn the key the two red dash lights (hydraulic pressure and generator, I don"t remember which on is which) light up. The one on the left is very dim and the one on the right is bright. When I hit the starter button the one on the right goes dim and the left one gets brighter but no action from the starter. I have both of the batteries on battery tenders so they are fully charged, I don"t know if I have a loose connection or short somewhere.
Any suggestions on where to look?
Thanks,
Phil
msb
03-13-2008 18:03:09
 Re: 4020D 24 Electrical Problem in reply to Phil/PA, 03-13-2008 12:54:17
In addition to what Bob suggests, check the neutral switch or switches if a Powershift. There is one behind the right hand battery. The PS has another on the inching pedal.
msb
03-13-2008 18:03:17
Bob
03-13-2008 13:53:11
Start by checking and cleaning ALL the connections at the battery posts. Then make SURE both batteries really ARE fully-charged.
I ALWAYS wear eye protection when doing this. After seeing a few batteries blow up in my time, I can tell you it's a good idea.
