4010 draft controll
c.w
03-12-2008 15:35:22
I got a 4010 that i pull a heavy 3 bottom rollover plow, When the draft controll is in the draft position it will yank the plow right up, in load-draft it will pick it up about a foot, in load position it wont pick it up at all. Any advice before i take the rockshaft cover off and get in over my head. thanks
c.w
03-13-2008 14:38:34
 Re: 4010 draft controll in reply to c.w, 03-12-2008 15:35:22
I went out and adjusted nut in the diffirential housing,as per the instructions in my book, and now the plow goes up in all 3 positions, so thanks for the advice guy it was dead on
Tx Jim
03-13-2008 03:49:24
 Re: 4010 draft controll in reply to Tom 43, 03-12-2008 15:35:22
I agree with LarrySTN!!!!! "Proper adjustment" of the L&D mechanism solves alot of problems.
LarrySTN
03-12-2008 18:01:59
The D position is for Depth not draft.
L-D =Load & Depth
L is load
It should always lift in the depth position, but will not raise properly in the other postions if the linkage is out of adjustment. Its not hard to adjust but too lengthy to post here. But an I&T manual and follow the instructions.
Josh in WNY
03-12-2008 15:53:47
Not sure if this will help or not. I have a 4020 that I'm ripping apart because the 3pt hitch will move up, but will not lower back down.
First thing I would check would be the reverse signal lockout on the hitch assembly. It's a bolt that limits the motion of the hitch assembly.(4010's might be different than my 4020)
Second thing I would check would be the control valve adjustments. Most technical manuals describe how to make the adjustments to these parts.
There is also an adjustment for the draft link extention that rides on the rocker shaft. You can access it from a plug in the back of the axle housing (somewhere near the serial plate). Just reach in with a screw driver and turn.
I'm not sure if it is the problem or not. It adjusts where the cam from the control valve is positioned. I think it is what is the matter with my 4020. (someone screwed it up before we bought it, but for $4,000 we couldn't pass it up) You might want to ask one of the service guys at a dealer for more info before you try adjusting this part.
Hope this helps. I'm sure there are a lot of other guys on here with more experience than me, so if I'm wrong, please point me in the right direction before I mess my tractor up even more.
