Help Brake lockup
OCB
03-12-2008 09:03:09
A neighbor has a 5203 tractor that has the right brake lock up for no appartent reason. I think it may adjustmen but the Operators manual is lacking.
The problem is the left brake pedal has about 4 inches of free play while the right brake pedal has 1+ inch. After you drive the tractor 3-4 minutes the right wheel fails to turn and the right right blade pedal has no free play. The only way we got the tractor to move is turn the engine off hit both brake pedals a couple times and the right brake pedal gets free play again.
I don't understand the master cylinder, is it using hydrualic boost or ??? What is the problem???
OCB
03-13-2008 08:18:35
 Re: Help Brake lockup in reply to OCB, 03-12-2008 09:03:09
The problem was found in the linkage at the control valve. A set screw backed out, the linkage slipped and after use the pressure was not released thus lockup. The dash required removal to really see problem. Thanks
mattd
03-12-2008 18:10:51
there is no master cylinder or hydraulic boost. it is all hydraulic pressure from the tractors pump. totally different than automotive. im thinking its probably the brake valve. one of the valves may be scored and leaking pressurized oil to the brake pistons. i would start by rebuilding the brake valves. if that doesnt fix it then pull the right final drive and see what the brakes look like. make sure the disk isnt warped and piston o-rings are good.
