1010 Road Speed
Genos
03-11-2008 20:30:24
A Friend Bought A 1010 Gas Utility & Has Not Gotten A Book Yet & Wants To Know How Fast It Will Go In high gear? He Wants to take it on a tractor drive. Thanks
Loren NC
03-14-2008 12:39:34
 Re: 1010 Road Speed in reply to Genos, 03-11-2008 20:30:24
The answer is probably at his finger tips. He needs to crank the engine to full rpms and read his tach. It gives the ground speed for each gear and each rpm level.
jjamna
03-12-2008 19:23:51
The hard part is finding one with the frontend that is tight enough to go full throttle in high gear
1958johndeere620
03-12-2008 14:01:15
I don't know for sure but I think it is 15 mph. I used to have one but sold it and the books went too. It also has a govener overide which makes it faster. Pull out on throttle knob and pull down some more. You can increase rpm's quit a bit. It should keep up with most tractors. I used to drive mine on road quit a bit from job to job and it went along good.
