Fuel Line Barbs:
Momsworry
03-11-2008 17:58:12
I guess that's what they are called. The brass things that slide onto the end of the fuel lines. I have a 40 A and had to remove the fuel valve and sediment bowl. Now the lines leak and not matter what I do how tight or not tight, they leak. I'm assuming I need these new barbs. Does Deere sell these? How much roughly are they worth?
Momsworry
03-11-2008 19:22:32
 Re: Fuel Line Barbs: in reply to Momsworry, 03-11-2008 17:58:12
These are the steel lines. I'm talking about the brass compression rings that seal the ends of the original steel fuel lines. After they have been tightened some over years, they lose their shape and sealing quality and I think must be replaced or am I missing something here? Is there another way I can seal these? If so, please share.
PBrowning
03-11-2008 22:19:33
 Re: Fuel Line Barbs: in reply to Momsworry, 03-11-2008 19:22:32
Yes - you have missed something! What you have is a perfectly good alternative to the Deere parts your tractor came with, except that they leak once they have been disturbed! If that's what you want to run with, take the fuel line to your local Ace Hdwe or NAPA and fetch replacements for those. You don't need a part number or a correct name -- you have the pattern! (PatB)
wilamayb
03-11-2008 19:42:55
Please pardon. I did not read the question well enough. I think Pat has you taken care of.
I saw "barb" and thought you were speaking of the hose barbs to connect pieces of rubber hose.
PBrowning
03-11-2008 18:59:16
The parts you seek are the A2069R Nut and E2150R Gland -- these for fuel line with 5/15-inch OD.
Both of these little jewels are available from Robert's Carb (712) 262-5311, and I rather imagine they also will be found as valid in Deere stores. (PatB)
Bob
03-11-2008 23:41:31
 Re: Fuel Line Barbs: in reply to PBrowning, 03-11-2008 18:59:16
Deere still has the E2150R solder-on "glands", @ about $11.00 each.
wilamayb
03-11-2008 18:18:46
You can purchase new fuel hose and barbs from any parts store.
Have you considered replacing those old rubber hoses with some original steel lines? They may suit you better. I think they look much nicer.
