70 Crankshaft, left side
super99
03-11-2008 14:58:33
third party image
Here is the left side with dial indicator set up, is this the correct way? Chris
Mike M
03-11-2008 19:23:42
 Re: 70 Crankshaft, left side in reply to super99, 03-11-2008 14:58:33
That is the Right Hand side not the left.
F-I-T
03-11-2008 15:24:54
Chris:
You can do it that way, but you ought to measure it 90* to that direction as well. If the clearance on the top and bottom were nil, but the bearing had been deformed, worn, or otherwise distorted/elongated in the fore and aft direction, you would not know. I prefer to remove the crank and measure the crank journal with a calibrated micrometer, and measure the main with a dial bore gauge. While the crank is out, you can measure concentricity of the journals if you have access to a height gauge and a pair of machine centers.
Your method will do what you need for what you are likely after. I would measure it in both directions, spin it 180* and repeat. Maybe a few times, write everything down and then analyze it, just to be sure you indeed have a "0" clearance. You will need to adjust that if true.
HTH
Frank
THE SMOOTHED DEERES
03-11-2008 17:05:39
 Re: 70 Crankshaft, left side in reply to F-I-T, 03-11-2008 15:24:54
Fit i was wondering if you have any photo's of the restoration on your 70 ? I would like to see them.
super99
03-11-2008 17:22:27
 Re: 70 Crankshaft, left side in reply to THE SMOOTHED DEERES, 03-11-2008 17:05:39
Not restoring it, just trying to get it to run good enough to use it around the farm. I've had it since about'88, and it got so weak, it would hardly start. Pulled the head and pistons, and the top ring groove was burned off of both pistons. Got a new set of pistons, and had them fitted to the block, and getting ready to put her back together. Tractor club I belong to is talking about a plow day this spring, and I would like to give her a work out, and then use it around here.. Can post some pictures as it goes back together. Chris
buickanddeere
03-11-2008 19:33:35
 Re: 70 Crankshaft, left side in reply to super99, 03-11-2008 17:22:27
The crank has not been out? The cylinder block hasn't been off the crankcase?.New or used pistons? Cylinder wall condition and clearances? There is a center bearing on that crank that needs to be measured and visually inspected. There is also a factory service bulletin to plumb a oil pressure line to the center bearing. The factory made that an upgrade on the new 720. It's a pile of work but it saves having to take everything apart the 2nd time. There are two different types of pistons. The original with a wide shallow bowl. And the improved 720 and later pistons with a narrower/deeper bowl. Ideally the injector tips should be changed to suit the piston. If nothing else the tips and copper washers are economical. The old ones have to be worn with age and hours. With the injector pop pressure set in a diesel shop and fresh tips. She will start and run even better. Less wet stacking too. The engine will run with more power and less smoke/stack slobber with 195F thermostats. Tinkerers in the old days tended to toss the thermostats in the grass out behind the workshop. The bearings and timing gear have to be in top notch condition. Or the engine will suddenly stop..... .. There are very good manuals for a reasonable price from 1-800-522-7448.
70 puller
03-24-2008 20:50:39
 Re: 70 Crankshaft, left side in reply to buickanddeere, 03-11-2008 19:33:35
i have pulled a cam out of a 70 gas before without pulling the crank or letting it out of the mains. Just pull the gear off the cam and it can wiggle out with a little work.
super99
03-12-2008 01:25:15
Tractor is a gas model.Bought pistons set from this site, took block to machine shop and had bored to fit pistons and new pin bushings. Have new rod bearings, and wanted to check mains while it was this far apart, probably should take the oil pump apart and check it out? Then need a new flywheel. Thanks, Chris
buickanddeere
03-12-2008 07:14:10
 Re: 70 Crankshaft, left side in reply to super99, 03-12-2008 01:25:15
Oops. This is definitely the time to pull the cam & lifters. They will need truing up. Part of the poor running is likely due to timing and lift being off. Wear that your eye can't see will keep an engine from running properly. The distributer will need a new bushing as well. New bolts in the flywheel too.While there are usually re-used. Those tractors later sport a worn flywheel and crank splines. Still should have a 195F stat.
JDBert
03-12-2008 08:02:52
 Re: 70 Crankshaft, left side in reply to buickanddeere, 03-12-2008 07:14:10
To pull the cam and lifters you also have to pull the crank on a 70 gas since the lifter block is part of the main case unlike say a G where it unbolts, it can be done IF you have the mains off, the crank will drop enough in the crank case to get the cam out.
buickanddeere
03-12-2008 18:26:30
 Re: 70 Crankshaft, left side in reply to JDBert, 03-12-2008 08:02:52
If in this far, it only makes sense to freshen up the cam/followers.
