70 Cranckshaft bearing play
super99
03-11-2008 14:55:58
third party image
It finally warmed up a little bit, time to get back to work on the 70. Head is done, block and pistons are done ready to pick up. I want to check the main bearings, found a dial indicator in my fil's old tool box. Is this set up correctly to check clearance? The right side, I set it up and cannot move crankshaft at all. On the left side, I set it up, and can move it up & down and the dial reads 10, I assume 10 thousands. Do I have to take the reduction gear cover off of the right side to check for wear? Any thoughts, first time into a 2 cylinder. Chris
