Clueless in Minnesota
farmboy169
03-10-2008 21:41:24
A few of you might know that I just got my first job restoring somebody else's tractor. I looked at it today, and it isn't that bad. It has good tin, and it runs. The two big things that this little "50" needs are all new tires, and alot of gaskets. Pretty much from the valve cover all the way back to the Power-Trol outlets is one big oil pit. The guy wants it running like a top, sandblasted, painted, and no more oil leaks. My question is what is the going rate for labor when doing something like this. Please keep in mind I am no Gary Uken!!! I am very wet behind the ears. Thanks ya'll
PBrowning
03-11-2008 22:26:38
 Re: Clueless in Minnesota in reply to farmboy169, 03-10-2008 21:41:24
farmboy 169 -- NOW, you need my book!! I say this since John Deere SE Paint & hardener were mentioned by msb! The Book's chapter on paints is the cheapest form of insurance you will ever buy. Miss-use 3-part paint and you may end up paying for it with misery the rest of you days!
Call me (830) 627-0430. (PatB, The Texas Shorthorn)
msb
03-11-2008 18:14:27
I sand blasted two tractors. My first and my last and it was the same tractor. Even the cast is destroyed in its original appearance. Keep track of your time and then cut it in half for the training you are getting. You can charge more the next time as your skills increase and you know more about restorations. Think of it as tuition. Regardless of what finish coat you use, use the epoxy primer. The old classic Deere green can look really sharp if you include some hardner in the paint.
J Chantry
03-11-2008 18:05:56
I restored a 49 M last summer for a friend of mine. He wanted it to look like it did when his father bought it in 49. After many gaskets, parts, tires, and paint (PPG Omni acrylic enamel) later, it did look like new.
But, as many say, restoring an old tractor is a labor of love, not a way to make money.
Parts and material cost $3500, I charged him $2000 for labor. I probably made $4 per hour. It took me probably 40 hours alone to get the sheet metal straight and the dents out.
But I did have fun and another old tractor was SAVED!
Wayne_H
03-11-2008 14:42:24
I don't know about everyone else, but it seems to me whenever I tear anything down "just to clean it and paint it" I end up finding more and more mechanical issues that need fixing. Examples:
- Let's see, how long has this broken off 5/16 inch tap been in the radiator housing?
- How much will it cost to ream out the clutch linkages and put in new bushings...
- And that starter...
- And the pesky wires don't look right with home depot wire...
- And those 5/8" threaded holes appear to not be threaded anymore, so how are we going to fix that...
- Oh, and that bearing is bad....
- Geeze, these rubber bushings are not supposed to feel like concrete???
I love doing it, but doing it to make money might be expensive for the customer if he wants it done right.
I do wonder what Gary U charges for a real restoration? It's got to be many many thousand dollars.
Good luck!
Wayne
Jerry Pevehouse
03-11-2008 10:48:10
A lot of good ideas so far. Every tractor I have restored, has been taken down to the bare case. Every part (almost) has been sand-blasted, individually primed with epoxy primer and painted with automotive grade paint. I know the majority of responses here would disagree with at least one or two of these topics, but I was brought up to do the best at what I attempt. Not everyone is as particular as me, and I respect that. I will give one more clue, that I never sandblast the transmission or engine cases. I usually clean them up with a wire wheel or something. You cant be too careful when it comes to getting sand or silica into these areas. If you are going to sandblast anything, make sure it is clean of dust or sand before you prime and paint. I usually prime, paint, and assemble, then shoot a good final coat before I call it good. When considering gaskets, seals, bearings, and felt washers, you can do the job several different ways. I usually order all the gaskets from Deere, for gasket thickness for different applications differs greatly, and getting things to match up the way they were intended to be is necessesary. In addition, if you are going to restore a tractor, change EVERY gasket. If you don't, I guarantee that will be the one that will leak. Change them all or you will regret it. I cut many gaskets myself, if I know the thickness, or if it isn't critical.
There are just as many ways to restore a vintage tractor as there are folks on this site, each to his own. Guess I like winning best of show too much to change, or maybe I just love old iron more than life itself. Good luck in your project, but as others have stated, restoring tractors correctly can be very time consuming, and that is why some of the pros charge what they charge. Jerry
buickanddeere
03-11-2008 10:25:51
High pressure hot soft water with dish soap. Sandblasting is for cleaning rude words off brick walls.
PBrowning
03-11-2008 09:25:46
Sandblasting -- I will be quite blunt about this! You will be sorry! Cleanup is only possible by taking the entire tractor down to the piece-part level. Besides -- if you think you can easily blast away caked on oil & grease, give that one up. Sand granules has a propensity to "bounce off" -- sand blasters surely don't like to do it!
I would consider sand blasting for selected pieces once they have been removed from the tractor. Don't overlook electrolysis as a means of clean-up either. It is quite effortless insofar as hard labor is concerned, very cost-effective, and folks that have used it rave about the process.
Cleaning a tractor is an art, and not all that hard. The cleaning process goes on & on until disssassembly is finally done. Control of oil and grease soon becomes a major objective. Do it right and believe me, your wife will love you for it. Screw it up and track that crap into the house and you will see another side of her!
I sell a restoration guide which you would find super valuable from this single standpoint alone, and you can learn a little more by visiting my site, or an email. (PatB)
Jeremy B
03-11-2008 08:55:14
I have been around a lot tractors that have been sandblasted and that sand will be in a lot of places you don't want it to be. I clean everything piece by piece oven cleaner does wonders on a lot of parts. I buy rolls of gasket material and cut my own gaskets it takes a little more time but I saved about $300 on a tractor I did recently. Don't forget about anything you may have to take to a machine shop if you don't have the resources to do the repairs. The machine shop I work in charges about $60 hr that can really have an effect on your price. Good luck on your project!
Mike M
03-11-2008 07:08:36
If it is anything like my 50 EVERY and I mean EVERY ! gasket on it was bad. I almost didn't tear it all down , but glad I was because I found alot of bad gaskets. Good thing was most of the expensive parts were fine. I did another 50 for someone else and had it plastic media blasted first then primed then I did what tear down I needed to do and cleaned out the blasting media from everything in the process. I'd NEVER blast one without planning to tear it apart and clean it out later. That stuff gets in all over ! You are talking about ALOT of time to do what you say and it will easily exceed the value of the tractor. Hope they are prepared.
THE SMOOTHED DEERES
03-11-2008 07:20:50
 Re: Clueless in Minnesota in reply to Mike M, 03-11-2008 07:08:36
Iv'e never been a fan of blasting either. Just clean it part by part .
danb4230hc
03-11-2008 06:30:02
As a "first timer" it's difficult to understand what it really costs to operate as a business. If you figure out what you want for your personal wages, let's say $20/hour, you then need to add for the small consumables you will use in the process like cleaning solvents, gasket stripper, sand paper, emery cloth, misc. nuts and bolts, and so on. Let's throw a figure out there of $5/hour for your consumables. If you are heating your shop which I assume you are in MN, you need to figure out what is costs to heat your shop. I assume MN also charges property taxes on your building so you need to figure that in also. Also add for your property insurance. As you do these repairs you will undoubtably make trips somewhere to get parts so you need to add about $.50/mile for your trips. While using your own tools you will need to factor in something for wear and tear on your tools because they don't last forever. By the time you factor in all of your expenses you will probably end up in the neighborhood of $38-$40/hr. This may sound high to someone not used to calculating real costs in doing business, but it is actually quite low. Since this is your first time you may make a mistake or two and decide not to charge for your time to undo a mistake. The best thing you can do before starting a project like this is to be up front with your client and let him/her know you can easily end up with several hundred hours on a project like this. Also keep them informed at regular intervals, say weekly what your progress is. This will give them a "comfort level" with your progress. I like to take lots of digital pictures as I go, and send them via e-mail to the client so they know exactly what is going on, and what challenges you are running into. Good luck!
