JD430
Darrell Gaynor
02-13-2000 18:46:11
What is the HP and years mfg of the 430. Would it be a suitable tractor for bushing hogging and general purpose? Any idea of value for average condition?
steamer
02-15-2000 14:31:36
 Re: JD430 in reply to Darrell Gaynor, 02-13-2000 18:46:11
The 430 were 1959 models, but are really no different than the 420's, other than the dashboard and tin. They're 30 HP class and make excellent tractors for mowing. I have one I use an 8' finishing mower on, or it'll easily handle a 5' bush hog.
There are several sub-models, identified by letters (430S, 430U, 430T, etc) denoting the basic arrangement. The (S) standard and (T) tricyle are the most common. The (C) denotes a crawler, which makes an impressive bush hogger (if you can't cut it, knock it over!). The (U) utility is quite low to the ground, and the (W) row-crop utility (features of the tricycle with a heavy, wide, front end) models usually have more options on them than the others.
In fact, I recently listed my 430w on the classifieds but I guess it's too early in the year for anyone to want it. Drop me a line if you'd like to know more. I'm in the Raleigh, NC area.....
Phil
02-15-2000 06:47:55
I have a 430W.
Most books rate the PTO hp around 29 and manufactured in the '58 to early '60 time frame.
Bucheits (spelling?) farm supply here in Missouri has a used tractor book that lists years by serial number and suggested value by condition.
Try to get one with a live PTO or use an overriding clutch.
Don't go over a 5' bush hog or use with a slip clutch as we had to replace a PTO drive gear two times at $350 for part plus labor. (We brush hog fairly heavy stuff).
I never have used a finish mower on this tractor.
Kenneth Greene
08-23-2001 20:21:16
 Re: Re: JD430 in reply to Phil, 02-15-2000 06:47:55
Phil
Where did you find the pto gears?
DANNY RAY
02-14-2000 06:38:34
EXCELLANT CHOICE FOR SMALL FARM/ I USE ONE TO MOW APP 20 ACRES AROUND HERE YOU CAN EXPECT TO PAY $3000 TO $45OO FOR A 430
