JD 60 power shaft drive
54/60
03-10-2008 19:09:59
I was woundering if the power shaft gear and the power shaft idler gear can be removed and the tractor still be operable. The reason being is the power shaft gear is worn out and when the tractor is running it makes a heck of alot of noise. I do know this unit runs the PTO but I dont use the PTO, I just use it for tractor pulls.
buickanddeere
03-11-2008 10:29:45
 Re: JD 60 power shaft drive in reply to 54/60, 03-10-2008 19:09:59
Does this tractor have live pto? If so,You should shift the pto out of gear. The pto and hydraulic pump should be shifted out of gear if not being used to reduce wear,fuel consumption and HP drain. Needless to say many new and long term owners are shocked to find out it"s possible.
Mike n Mo
03-10-2008 19:24:15
Are you talking about the gear behind the 1st reduction gear? If so, it can be removed, but you need to replace it with a spacer, P/N A4425R. The spacer was used on tractors without live PTO. Mike
