4020 LP Electrical Problem
Pete Wilson
03-10-2008 14:35:13
I seem to be having a problem with my 4020 LP. I put it in the barn last fall, and went to start it and upon turning the key on, nothing happens. No dash lights or headlights. So I checked for voltage at the key, had 12volts to one pole with the key off, but when I turn the key on it goes to 0 volts on my meter. I made a jumper wire to go from the battery to the pole I have the disapearing voltage to and when I put that there the dashlights come on and the fuel selonoid opens, but it wont turn over...? I think I have more than one problem..any help?
danb4230hc
03-10-2008 16:41:55
 Re: 4020 LP Electrical Problem in reply to Pete Wilson, 03-10-2008 14:35:13
Typically if the voltage drops to "zero" when you connect or complete a circuit, you typically have a poor ground/connection, or the battery has no reserve such as being discharged. Have you cleaned your battery posts? Are the wires clean and tight on the battery, key switch, and starter? What happens when you connect another known good battery to the tractor?
bill mart
03-10-2008 15:19:30
how about trying a battery that you know has a full charge?
Pete Wilson
03-10-2008 15:38:00
 Re: 4020 LP Electrical Problem in reply to bill mart, 03-10-2008 15:19:30
im confident the battery in the tractor is charged enuff to turn it over, becuase I have bumped the started by jumping across the selenoid
