60 engine speeds
Bob with a 60
03-10-2008 10:34:44
Have been studying the difference between 60 and 620. Seems the 620 runs a bit faster than a 60. Was told this is because of the aluminum pistons in the 620 reduce mass. So my fresh overhauled 60 with .125 over aluminum pistons,well can it be set to the 620 engine speed specs safely to get a bit more power?
1958johndeere620
03-10-2008 18:16:24
 Re: 60 engine speeds in reply to Bob with a 60, 03-10-2008 10:34:44
I have seen a JD model A that had his pto rpm's up to like 740 and on a dyno he didn't make a drop of power over stock levels. So I agree that in the case of a 60 rpm's don't always give you power.
buickanddeere
03-10-2008 13:14:05
Volumetric efficiency is on a slope downwards at rated HP. More rpms gain no HP what so ever. Ports are too small in diameter, too long and cam timing too short. The engine is built to mmake rated HP at 975rpms and peak torque at 700-800rpm.
Mike M
03-10-2008 12:00:16
The 620 also has a totally redesigned engine. Heads have the plugs in them,pistons have a dome in them. You likely won't hurt your 60 any with a slight speed increase,but it may not really make any more power either. It will still have to pull down some to make the power. At the very least put a tach. on it and make sure you are up to the rated fast idle speed ( wide open throttle no load ) just a little less then where they are to be can really kill the power you have.
