4430 leaking SCV coupler
BobinIL
03-10-2008 08:35:47
The scv connection on the back of my 4430 leaks terribly when hooked up to my soil finisher. Can I fix this my replacing the o-ring inside the coupler or do I need to rebuild the whole coupler?? I am new to the green equipment and do not want to sound like a fool when I go order the parts. My old red tractors never leaked at the couplers. Is this a common problem with older deere's
DONMYEIL
03-10-2008 09:33:59
 Re: 4430 leaking SCV coupler in reply to BobinIL, 03-10-2008 08:35:47
Most likely the o-ring (quad ring)and backup washer is bad.If coupler only leaks when a hose is hooked up.Also check the hose coupler as they will go bad as well.
