820 differential again
toolz
03-09-2008 20:51:45
I posted earlier about the side play in my 820's differential, and I found out tonight that I was mistaken about how that works. The side play, measured at the ring gear, is within tolerance. The play I was worried about is how much the pinion drive gear moves side-to-side. After checking the manual, I realized that the side bearings will not move in to tighten that up. The manual doesn't give a spec for side gear tolerance. Does anybody know what is acceptable? Mine seems too loose, at .093". Thanks again for your help.
WeirdDeere
03-11-2008 01:22:09
 Re: 820 differential again in reply to toolz, 03-09-2008 20:51:45
Are you talking about the countershaft and the "differential drive pinion" on page 45-5 of the parts book? You have SIDE TO SIDE play? That's weird. No, I don't believe you can take that up in the bearings at all. Are you sure it's the gear itself, or the whole shaft moving side to side? If the gear is moving...the spacers must be whipped...but that would be hard to do! I'd look at the bearings again?
I had a problem with that gear too...I had radial motion...the gear would rotate quite a bit before moving the shaft. The splines on both the gear and shaft were whipped. But it didn't move side to side like you describe. In fact the bearings weren't TOO bad. Of course, getting them out destroyed them.
I just reinstalled my countershaft a few weeks ago. I still need to put the left hand bearing and race in, but ran out of warm weather. Unfortunately for ya, I can't measure the spacers with much accuracy now that it's in.
third party image
The pinion drive gear is the one right in the middle (some spots of rust), to the left on the spacer with writing on it.
Have you seen the thread describing all this on the Johnnypopper board? My 80 Tranny Here
Brandon
toolz
03-11-2008 08:04:58
 Re: 820 differential again in reply to WeirdDeere, 03-11-2008 01:22:09
Brandon & Mike- Thanks for the replies. The gear I'm talking about is on page 45-8 "differential bevel gear". Since the diff shaft is shouldered under the end bearings, the play cannot be taken up by shimming the left bearing housing. There is no play in the bearings. I guess there is enough wear over the decades in the thrust washers and especially the pinion gear teeth to cause some side-to-side movement. I just don't know how much is acceptable. I intend on pulling the left bearing and making a spacer to go between the thrust washer and the diff bevel gear to take up most of the slop, so the diff gears will more fully engage each other. It was working fine, but the less tooth engagement it has, the more chance there will be to break off the pinion teeth under load. If you guys know how much side-to-side play is needed in the diff bevel gears, please let me know. Thanks again- Kevin
Mike M
03-10-2008 07:35:14
Is this a 2cyl. model ? or a 3 cyl. model 820 ?
I guess I assumed it was a 2cyl. ? and if it is the shaft that drives the differential is usually called the lower countershaft. And about everyone (2cyl.) I ever had apart was WAY out of spec. too. Between wear in the bearings and the gears and spacers being banged together and indented clearance can get pretty large. I'd really be giving those bearing a close inspection !
