4320 Transmission Insight Needed
Tom
02-13-2000 16:23:03
Just got a 4320 on the open market; a mechanic at the dealer said they used the stock 4020 gears when the turboed the 404 up to the 4320's horsepower, and that you can blow out the rear ends because of this. Any experience or advice here guys; I can't afford that kind of mistake. Also, any other advice regarding the 4320 will be appreciated.
Terry
02-14-2000 06:09:39
 Re: 4320 Transmission Insight Needed in reply to Tom , 02-13-2000 16:23:03
The 4320 was built heiver than a 4020 to make up for the added horsepower, ours has been used alot, none of it very easy, most at 99% capacity and have not worked on trans in 7,000+ hrs. They are well built tractors, but like any, there is someone that can tare them up .
Terry.....
Doug
02-13-2000 16:37:15
Does your 4320 have a trasmission temp. guage? If it does just keep an eye on it. I've never had any trouble with ours, but it is used for pretty much light duty now. The previous (original) owner used it hard and didn't have any problems that I know of either. Occasionaly I hook on to a 5-18's plow and plow some sod or water ways with it and it has never acted foul. Just use some common sense and you should get along fine with it I would say.
4320NUT
01-23-2004 18:50:50
 Re: Re: 4320 Transmission Insight Needed in reply to Doug , 02-13-2000 16:37:15
You can probably pull 5-18's in 6th gear can't you>
