Early styled A shutter and controls
Walt in Jaxn Tn
03-09-2008 16:59:43
Where whould I look for a rod used on the "A" with starting and lighting ser. no. 477000-583999. the rod goes from the handle, control on the dash to the lever under the hood. The part no. in my March 1950 "A" parts book is A 2236 R . I see where Sharps is reproducing some of these parts, but, I didn't see this one. Any help appreciated Thanks --Walt--
Dave in SV
03-10-2008 03:17:52
 Re: Early styled A shutter and controls in reply to Walt in Jaxn Tn., 03-09-2008 16:59:43
Make your own?
Walt in Jaxn Tn.
03-10-2008 10:46:16
 Re: Early styled A shutter and controls in reply to Dave in SV, 03-10-2008 03:17:52
I have to have the exact dimentions of the origional rod for the long hood "A" I have the rod for the hand start "A". --Walt--
Dave in SV
03-10-2008 15:10:37
 Re: Early styled A shutter and controls in reply to Walt in Jaxn Tn., 03-10-2008 10:46:16
FOR THE LATER STYLED A: the long rod (from control arm to pivot under hood) is 1/4" diameter, threaded on one end to mate up with the adjuster coupling, 49-1/2" long, plus a 1/2" long 90 degree bend on the end opposite the threaded end. The shorter rod (from the pivot to the shutter) is 1/4" diameter, no threads, 15-7/8" long, plus 1/2" long 90 degree bends on each end. On this shorter rod, the 90 degree bends are twisted 90 degrees from each other as well. This is somewhat hard to put to words, but when you look at the way the linkage hooks up, I think it will make sense. I am NOT sure if these specs will work on the EARLY STYLED A!
Anderson
03-09-2008 17:13:26
Try Kim Johnson in Minnesota. He has alot of used two cylinder parts. 218-729-7143
