48 B Electrical Question
davebr
03-09-2008 14:13:47
Alright, Here is what I am going to do. I have a 48 B with a Delco Remey Distributor on it. I am going to take the generator to the shop and make sure it is converted to 12 volt neg ground, 12 volt coil, 12 volt bulbs etc.. Now , I am going to rewire the whole tractor, should I just follow the manual for that? What a bout the cut out relay?
Dave
John T
03-09-2008 16:49:29
 Re: 48 B Electrical Question in reply to davebr, 03-09-2008 14:13:47
Dave, M Mans wiring diagrams should contain what you need, all you have to decide is whether to use a 3 brush generator with a 2 wire cutout relay and a Low/High Charge light switch or upgrade to a full fledged Voltage Regulator system (it doesnt use light switch regulation). If originlity is an issue the original 6 volt system with a cutout relay can be made to work fine but if youre gonna upgrade to 12 volts anyway you may as well go all out n use a Voltge Regulator (I prefer the original myself). Decide then use the appropriate diagram.
Link
John T
PBrowning
03-10-2008 06:19:56
 Re: 48 B Electrical Question in reply to John T, 03-09-2008 16:49:29
A much improved wiring diagram set can be found at the JD-H Restoration Site (below). Scan across to ARTRICLES 2, and from the drop-downs, momentarily select WIRING DIAGRAMS 3, and from there select your model's wiring charts. (PatB)
The Texas Shorthorn
farmboy169
03-09-2008 15:44:53
Yes I would just follow the manual. It should be the same as a 6 volt diagram, but you'll have all 12 volt components instead of 6 volt. So should be the same system, just 12 volt.
TractormanNC
03-09-2008 14:42:01
Trash the cutout. Get a 12 volt voltage regulator. NAPA VR898, (Delco 1118779) flat bracket mount or VR899, (Delco 1118791) curved bracket mount.
