A water pump
Resting Relics
03-09-2008 13:30:17
Hey Guys, I"m working on my 52 A water pump that was added some time in it"s life as it"s too early a serial # to be factory. I have it apart and the pump does not match the parts book breakdown for an A. The cast in part number on the impeller per my master parts book list it as fitting a late 60 and a 620-630. Does any one have a 620 parts book that could post the parts page for the pump here on the forum so I can order the correct seal, bearing,retaining snap ring and impeller. The A parts don"t match so I assume the pump assembly when added must have been from late 60 or a620. Any help would be much appreciated 620. John
fixerupper
03-09-2008 15:30:36
 Re: A water pump in reply to Resting Relics 1, 03-09-2008 13:30:17
In the parts book I purchased through Deere it's on page 25-9. impeller part # A5319R bearing #JD8515 seal#R32622R gasket #A4281R Hope this helps. Jim
restingrelics1
03-09-2008 16:53:59
 Re: A water pump in reply to fixerupper, 03-09-2008 15:30:36
Thanks Jim, One last thing. Do you see the part number for the retaining snap ring that positions the bearing in the housing. The old one is real rusty. I,m not sure I could reuse it. Again thanks for your help. John
fixerupper
03-09-2008 19:37:42
 Re: A water pump in reply to restingrelics1, 03-09-2008 16:53:59
Retaining ring is R1529R. Jim
Resting Relics 1
03-10-2008 04:19:35
 Re: A water pump in reply to fixerupper, 03-09-2008 19:37:42
Jim, Thanks for your help. It's guys like you who make this hobby so great. John
