4000 Cab
larryanderson
03-09-2008 03:09:09
Was it possible to order a factory roll-guard cab.I have seen some with the roll-guard canopy.If so was air available?Also was the diff-lock an option? THANKS!
powertech84
03-09-2008 19:40:06
 Re: 4000 Cab in reply to larryanderson, 03-09-2008 03:09:09
the only difference between the 4000 transmission and the 4020 transmission is there is no sychronizers on reverse for the 4000
green northern light
03-09-2008 19:30:53
I was told by jd dealer in Manitoba. In late 71 & 72 JD waterloo trac. sales were very slow ,dealers in northern plains ordered 4000's equiped any way a 4020 could be equiped, I've seen 4000's as full standard's (no rockshaft, fixed thread front axle, 18" f. tires, big fenders, dust shields . ) I'd bet there's a 4000 or two ,up north with a factory Hinson cab. I've heard of single front wheel 4000 's with 42" rears in the west, onion & potato fields.
jd-tom
03-09-2008 17:58:07
I looked thru my brochures on the 4000 Tractor and in the first brochure printed about this tractor no diff lock is mentioned anywhere. A year or two later it is listed in the option list as well as the Roll-Gard and canopy (but no cab)
Gerald J.
03-09-2008 10:33:49
The 4000 came with the side console 4020 production. It was supposed to be a lower priced version to better compete with other makes on price. Its sure the early and late 4020 could be had with cabs. While the cab parts are in the early 4020 parts catalog, they were all made outside Deere. And I don't know any actually were strong enough to act as a roll bar. Those I've seen in person had only light angle in the corners to hold the tin and that's not strong enough to hold up the tractor.
Some believe that the 4000 had the 4010 transmission, because it's axles were the same size, but others have said the 4000 final drive and transmission parts were unique and so I don't know about the differential lock as an option. I KNOW it is very good to have in worked soil and could almost double the tractor performance. Disking plowed ground without the differential lock my 4020 hops from one rear wheel to the other with the other in the air spinning. Locking the differential stops all that.
Gerald J.
Tx Jim
03-09-2008 05:51:04
 Re: 4000 Cab in reply to brians in sd, 03-09-2008 03:09:09
I think a cab wasn't an option on a 4000. I can't remember about diff-lock but I'll guess it could be ordered.
