Delco-Remy starter
farmboy169
03-08-2008 18:34:14
I had the starter for my D rebuilt and ready to run by a JD mechanic that is very good with these 2 cyl. I noticed the Bendix drive does not retract all the way in. In normal resting position in only retracts MAYBE a 1/2 inch. Common sense tells me this is not right, but is it? My neighbor has a D also and he says the same thing with his starter. He actually shimmed his starter out so it misses the flywheel ring gear. Do I have to take the nose cone off again????
farmboy169
03-09-2008 15:40:21
 let me rephrase that!! in reply to farmboy169, 03-08-2008 18:34:14
My post didn't make sense after I read it more. What I meant to say is when the Bendix drive is in the ENGAGED (starting) position, it only retracts maybe a 1/2 inch after the engine has started.
Mike M
03-10-2008 09:10:35
 Re: let me rephrase that!! in reply to farmboy169, 03-09-2008 15:40:21
Something sure isn't right ? Better have him look at it again or have someone else check it out too.
