820 axle bearing and diff questions
toolz
03-08-2008 11:25:29
I have my 820 apart to replace an outer rear axle bearing. I had a very hard time removing the race from the housing, using an internal puller on a big slide hammer. I finally used a die grinder and a carbide burr to cut through the race, and got it out. I tapped in the new race, and it spins in the bore. The bore looks perfect, and the race came from Deere, so what's the problem? It only has a thou or 2 clearance, but I can't run it that way. Since the old race was so tight, I'm sure the housing is OK. What do you think?
Also, while I was in there, I checked the side play in the differential. It was at .093, and should be .001-.004. There was .035 worth of shims under the bearing cap, and I can shim the race to make up the rest, but I can't get the side bearing to move on the shaft. I used a little heat on the inner bearing race, but I'm afraid too much will ruin the bearing. Any suggestions?
Thanks again for helping a 2-cyl rookie.
Mike M
03-08-2008 11:57:09
 Re: 820 axle bearing and diff questions in reply to toolz, 03-08-2008 11:25:29
Those diff. bearings are shot too. New ones likely should bring it back into spec. with the shims you have.
You may check on the specs. of that bearing that fits loose. See if it is what it should be. If indeed the housing is worn than loctite makes a product just for that.
toolz
03-08-2008 13:30:15
 Re: 820 axle bearing and diff questions in reply to Mike M, 03-08-2008 11:57:09
Thanks, Mike. The diff bearings (what I can see) look real good- I just figured everything was worn enough to add up. I would like to run with the diff parts I have- The tractor is just a toy for me.
I talked to Deere today, and they have another race in stock, so I'm going to measure it compared to my new one. I've heard about the loctite stuff. I was concerned that it may not work with all the weight that the race has to support. If all else fails, that's my only choice.
WeirdDeere
03-08-2008 15:40:54
 Re: 820 axle bearing and diff questions in reply to toolz, 03-08-2008 13:30:15
This whole discussion scares me. I'm rebuilding my 80's transmission...but only the stuff BEFORE of the differential. As bad as that is, maybe I don't want to know how bad my diff and final drive might be?
Brandon
Mike M
03-09-2008 05:28:05
 Re: 820 axle bearing and diff questions in reply to WeirdDeere, 03-08-2008 15:40:54
If your into the tranny with bad bearings I'd go ahead and check out the axle bearings. Put a jack under it and see how much play you have will be a good start.
toolz
03-08-2008 17:49:38
Brandon- It's not all that bad- my tractor was working fine, except for the axle bearing, and it will get fixed, one way or another. My diff looks good, and wasn't making noise, just would like to tighten it up while I'm in there. The trans is what scares me- it was working, and I'm not digging any deeper. An occasional plow day and a few pulls ain't gonna hurt it much. Good luck with yours!
