Wil, When you adjust the rear impulse stop plate, that ONLY AFFECTS the start impulse timing. Rotation of the Mag once its in the governor flange AFFECTS BOTH START IMPULSE AND ADVANCE RUN TIMING. To see where she fires at once running (over 250 RPM) you would have to use a timing light and then if you rotate the mag in the governor flange forward CW its retarded while backwards CCW advances it BUTTTTT TTTT that also changes the start impulse timing when yOu do that remember. Theoretically you first adjust that rear stop plate to match whatever drive cup you have and typically on a C or X Wico Mag thats 2 1/2 marks to the left of top center for a 25 degree cup and 4 1/2 to the left for a 35 degree cup and around 4 1/4 if its a 6713 drive cup best I can recall (Duane knows all those by heart) That gets the mag in the approximate correct center of upright adjustment for run timing buttttt t that all depends on the wear n play in the drive cup n rest of the mag THIS IS NOTTTTT A PERFECT system, this depends on the mag n drive n other system wear. I cover this pretty well n in detail when I give Wico C n X workshops but its hard to put alllll in a few paragraphs here. Duane and I approach this a lil different, I set the rear stop plate ( 2 1/2 to 4 1/2 to left of top etc) to match the drive cup I have, install the mag, n then fine tune n adjust the start impulse timing by rotation of the mag in the flange for a dead on TDC snap/impulse for best starting n then dont worry so much where she runs at maybe just check with a timing light n so long as shes from 20 to 35 let it be. hOWEVER Duane uses a timing light to adjust the mag in its flange for whatever advance run timing he wants, marks that position in the flange, then pulls the mag as/if needed to adjust the stop plate for the TDC start/impulse snap at his pre marked (for desired run time advance) position. Bottom line ,,,,, rear stop plate ONLY affects start/impulse timing while rotation of mag in flange affects BOTH. The Wico C n X was made to work on different tractors with different drive cups for different start impulse n run timings which is how n why those rear stop plates require adjusting and theres also rotational adjustment once its mounted. PS to intall the mag I get it first set right and then retard the flywheel/crank 90 degrees (governor drive flange then vertical) cuz when the mags cup is flat horizontal fore n aft (for TDC firing) that requires the spring to be wound sooooo oooo if its just in the pre wind (90 before ) position ut will sit there to be installed into the vertical governor female drive slot get it????? ????? John T
