420 wiring
Bob Evans
03-07-2008 08:08:03
I have a 420S that I am changing to 12 volt. Question = it is postive ground with 6 volt with the wire from the + side of coil to dist. so to go 12 volt neg.ground will the wire from the coil to dist. be the neg. Thanks
John T
03-07-2008 09:45:37
 Re: 420 wiring in reply to Bob Evans, 03-07-2008 08:08:03
YES
John T
buickanddeere
03-07-2008 08:46:12
Never seen a M/40/420/430 in decent condition that didn't start in the coldest of weather on 6 volt. I've even started the 40 with the hand crank at 10F in two turns.
Maark
03-07-2008 08:23:06
It depends on the battery ground. If it's positive ground, the wire from the positive side of the coil would go to the dist. If it's negative ground, the wire from the negative side of the coil would go to the dist.
