34 A Open Shaft Bearing Question
DScott
03-07-2008 07:23:56
I am starting work on a 1934 open fan shaft A and I am going to pull the fan shaft off and go thru it. Looking at parts book PC-674 I don't see any bearings listed. I could pull the existing bearings a let the bearing house reverse engineer them put I had rather not. Does anybody know what bearings go in it? Or where I can find out?
OLTWOPOP
03-08-2008 09:09:19
 Re: 34 A Open Shaft Bearing Question in reply to DScott, 03-07-2008 07:23:56
DScott,
I seen this in a old posting for (open fan shaft on GPA) hope it helps.
Deere doesn"t have the bearings anymore, but if you go to a good autoparts store (not autozone, etc.) order front wheel bearings for a 1957 Chevrolet Bel Air. They are the same.
Duane Larson
03-08-2008 09:50:28
 Re: 34 A Open Shaft Bearing Question in reply to OLTWOPOP, 03-08-2008 09:09:19
The three individual pieces that make up the bearing are no longer available, but the complete bearing is $44.28 according to JDParts.com. The equivalent wheel bearing number is ND 909001 if that is the desired route - depends where you can find that bearing - as I recall it was for a late '30's front wheel.
Duane Larson
03-07-2008 16:04:26
DScott,
The fanshaft bearing on your A is the same as on later A's - p/n JD7654 for the complete bearing. If you don't have a copy of one of the early Repair Catalogs (really a parts book) for the A, you should locate a 42-R (8-15-34), 47-R (4-15-40) or 57-R (7-15-43). The later parts books include a lot of substitutions, which may not be what you want. I think reproductions are available on eBay if you don't want an original. Also, Wes Malcolm's book on the unstyled A is invaluable - available from Green Magazine.
