45 b puffing and popping
eric
11-02-2003 15:05:56
the b has new .45 over rings,head redone.carb somewht redone by me. was running real well unill yesterday. the plugs(386)are getting black sout,powerer black on them after 10 min of running around the yard. it was running fine and would idel down real low and know it wants to pop or puff alittle. does not idel down hasa little black smoke when going up hill or starting of in 5th or 6th. was starting up on two turns but now will foul out after 10 to12 turns (hand start) i have noticed a little oil leaking around the pitcocks. what should i check first? thanks eric
Dave K (FL)
11-03-2003 08:44:54
 Re: 45 b puffing and popping in reply to eric, 11-02-2003 15:05:56
I had this problem develop suddenly with my 1948 Model A. After all the checks etc such as given by Cloony and John T here I finally discovered my head gasket was leaking compression between the two cylinders. Removed head and found a burned channel between the cylinders on the gasket. Replaced gasket and the tractor ran like new again. I agree this is probably not common but my symptoms were much like yours, fouled plugs after less than an hour, fluky carb settings that never seemed to be just right, rebuilt mag etc. I had not done a compression check but I would suggest you do so. I had removed the head because I just seemed to have tried everything else.
Dave
Dave
Clooney
11-02-2003 16:24:12
Eric, seeing as it ran good one day then not so good the next usually means something simple.
~Start with a look in the air cleaner oil cup, if you have water or junk in there clean it out... I doubt you have a plugged inner air filter mesh as your problem came on suddenly.
~Next make sure the choke is opening all the way, look at the index on the end of the choke shaft or pull the inlet pipe & verify it is actually opening, don't just assume that the choke is all the way open by the choke rod setting.
~It's possible you have some bad fuel in your tank [if you fueled up just before the problem started] or you just simply fouled a spark plug.
~It's also possible you have moisture in your distributor cap or plug wire tubes [verify everything is clean & dry]
~Maybe it's as simple as a fouled spark plug [quite common].. Try a new set of spark plugs just to eliminate that as a cause of the problem.
~That black soot on your spark plugs is normal on a non working 2-cylinder so that doesn't tell you much...
~That black smoke on throttle up as well as climbing a hill is also somewhat normal. The smoke should settle down & go away & after the initial load of climbing a hill is over though...
~You might want to sniff the engine oil, if you left the fuel turned on with the tractor parked you might have a crankcase full of gasoline [common if the fuel was left turned on] .. That will also show up as a rich running engine as the oil heats & allows gasoline past the rings..
~Maybe someone has messed with the carb settings so you might want to check the initial settings [you want the idle needle somewhere around 1-1/2 to 2 turns out from seated & the load needle somewhere around 3/4 to 1 turn out from seated. At least to start with, then fine tune from there after warm.
~If you re-set the idle needle for best idle at a very low RPM it is probably now too rich for a normal idle...
~While it could still be many other things, do or check the above & post back or E-Mail with any questions or findings.
[email protected]
John T
11-02-2003 15:57:23
Eric, that sooty black plug condition you described sounds like excess unburned fuel from running too rich or inadequate combustion, maybe partly due to a weak spark (especially possible on a magneto) or low compression etc, so to answer your question what to check first, I would say the carbs load and idle needle settings (maybe needed leaned in slightly) and the choke butterfly plate (tight on shaft and opens and stays open) and the air cleaner (clogged mesh??) and inlet pipe and bowl (clean and water free) for any restrictions, then the points for proper gap (0.015 on many Wico mags) and not carboned or burned or pitted or heavy gray oxide coated. REPLACE THEM IF ANY THAT EXISTS, that and the plugs and wires are another good first thing to look at per your question.
Runnign good then acting up suddenly sounds like more of an ignition problem like points or maybe condensor instead now all of a sudden an oil or compression problem to me. This is very similar to a post the other day, so to save me a ton of typing time, I cut and pasted it below as a troubleshooting guide. Here it is, but check the points and gap and plug wires and maybe lean the carbs settigns and insure the choke stays open first:
Heres a few thigns I would look at first (carb and ignition checks), and if they are all good then look at the compression and we will go from there.
1) That black color you mention on the plugs could mean youre runnign way over rich which can gas foul them fairly quick. Is it a flat black colored even sooty deposit????? ? That can be excess unburned fuel. Is it more of a shiny wet black uneven coat, that may be oil. If she dont blow a lot of blue smoke out the stack and have a lot of crankcase blow by, however, Im thinking more excess unburned fuel for the time being.
(I) FUEL RELATED CAUSES OF EXCESS UNBURNED FUEL FOULING PLUGS
a) Is the choke butterfly plate in the carb opening all the way and remaining open once youre up n running and its tight on its shaft and NOT free to roam around or close relative to where its set?????
b) Is the air inlet pipe and air cleaner and its bowl clean and water free????
c) Is the carb set too rich and does she black smoke a lot at idle or under load which indicates excess unburned fuel??? Have you tried to run the carb a tad leaner and see what she does and how the plugs look???
EXCESS BLACK SMOKE OUT THE STACK FROM UNBURNED FUEL (caused by a or b or c above) quicky fouls plugs leavign that even flat black sooty deposit!!!!! !!!
(II) IGNITION RELATED CAUSES OF INADEQUATE FUEL COMBUSTION
d) If you remove the plugs and have their wires atatched and them against frame ground and crank the engine, do both fresh new plugs produce a good visible blue and NOT a faint thin wimpy yellow spark??? If the spark is weak you dont get as good combustion. Post back what you have and model etc if the spark is weak.
e) If the spark is weak, look at the points and first insure they are gapped correct (0.015 on many Wico mags) and NOT burned or pitted or carboned up or heavy gray oxide coated. If so, replace them and try a heat range hotter plug. AUTOLITE 388
f) Is the cap clean and free of cracks or carbon tracks???
g) Are the wires good, no leaks, and wire core NOT carbon core auto suppressor types???
SUMMARY
The plugs and exhaust are a good indicator of whats happening. A lot of black smoke may mean restricted air from a partly closed choke or a clogged air pipe or filter or carb set too rich or even float level a bit high. Again, the flat black even sooty deposit is more a sign of a fuel or weak spark problem than an oil burner. Heavy blue exhaust and a lot of crankcase blow by is more a sign of a ring or valve or cylinder problem and that plus low compression readings leaving a wet uneven shiny plug coat will foul them but not usually in only a few minutes.
Look at the spark quality and plugs and points and cap n rotor and wires and check the air system and filter and choke. Try the cheap simple easy thigns first like air inlet and choke checks and points and wires BUT THE EXHAUST AND PLUG DEPOSITS IS A GOOD INDICATOR OF THE PROBLEM.
First thing suspect if the plugs are good and the chokes opening and no air restriction and the carbs not set over rich ARE SHE NEEDS NEW POINTS OR GAPPED, check that right off.
Post back or e mail [email protected] with any more questions. What kind of mag is it, cuz if the spark is weak, I will then post back more about ignition troubleshooting.
If the compression is low or very uneven between cylinders, then that can cause plug fouling and oil burning, so if the carb and ignition checks above test okay, we will look at ring or valve or cylinder problems next. Does she blow by much out the crankcase or blow blue smoke out the stack??? (oil burning)
Good luck n God Bless Eric
John T
