Gerald -- We could have a bad distributor cap, poor contact between distributor rotor and the No. 2 terminal inside the cap, a magneto timing issue � or, still a bad plug wire! 1. I'd pull the cap - look for "spark trails" where energy is draining off in a wrong direction, then clean the inside of the cap -- squeaky clean for openers. Inspect also for any signs of a crack or two because moisture and debris in such a crack will conduct energy away from its intended destination. 2. Inspect to see if the distributor rotor appears to be making as good a contact at the No. 2 terminal as with No. 1. Here you can have erosion of either of the two parts -- and erosion here adds resistance in series with the power path - thus less energy is delivered to the spark plug. 3. Now -- with the magneto button up -- Take an old spark plug, open the point gap of the plug to nearly �-inch. Remove the No. 2 plug wire from the magneto (safety). Connect the No. 1 plug wire to -- No. 1 at the magneto AND to the modified plug, grounding the plug base to the tractor. Two things: (1) When cranking the engine, you should see a blue spark make the jump, and (2) the spark should come when No. 1 piston is at TDC. STOP. 4. Now -- insert the No. 1 plug wire (still connected to the modified spark plug) into the No. 2 magneto terminal. Now with a mere 180� rotation of the flywheel, (1) You should have another blue spark jump across the modified plug gap, and (2) By coming at 180� after No. 1 (the no. 2 piston is now at TDC) you know the magneto is timed to the engine correctly. 5. All this testing has been done with the No. 1 sparkplug wire. Assuming a pass at each step, repeat the sequence above using the No. 2 plug wire. You may elect to start at paragraph 3 above, to para 4 & 5, and then if needed go back to para's 1 & 2. Feel free to write or call 830-627-0430 if you get bogged down. You also may pick up on something by reading the piece I have posted on the JD-H Restoration Website (below). Scan across to ARTICLES 1, and from the drop downs, select ELECT SYSTEMS. (PatB)
