Round spoke wheels for John Deere B
Dandy Don
03-06-2008 16:24:56
I need an expert JD B person here. Why do some round spoke wheels have twenty (20) spokes and some have eighteen (18) I just bought a 36 B today that has been sitting for more than 20 years and it has one flat spoke ( factory I think) "cause spokes are not welded at the rim) and a round spoke on the right side with twenty spokes.
It has a serial number but no engine. Crank is there but stuck of course. It has shutters and arms and all but is an under statement to say it"ll take alot of everything. If this old girl ever runs you can bet it will have been RESTORED "cause a paint job won"t help nuthin. I am thrilled though. Any infomation on the wheels will be appreciated. Don
easydoesit
03-07-2008 12:41:32
 Re: Round spoke wheels for John Deere B in reply to Dandy Don, 03-06-2008 16:24:56
Pulaski,Tenn? I have some unsty B's on steel & rubber. Easy 931-527-3602
JDNPC
03-06-2008 18:29:18
dandy don: try locating the casting # or posting a picture. duane is a guru in the wheel division. he has helped me and others tremendously. a picture is worth a thousand words
Duane Larson
03-06-2008 17:25:11
Dandy Don,
Unstyled B's came with French & Hecht HC177 round spoke wheels - 10 spline, cast in hub, 20 - 10" x 3/4" spokes, and used a B25R clamp. Two different versions of the hub are known - the first ones had casting bosses in the vicinity of the HC177, and for later ones this area was smooth. Various versions of the HC177 exist, for wide base tires, etc., but the ones I have cataloged have 20 spokes.
In the mid-40's Deere went to a flat spoke wheel with a bolt-in hub. The casting number was JD1270R for the 6.00S-36 wheel and JD1271R for the 8.00T-36 wheel. They were used on a number of models and years, as only the hub had to be tractor-specific. For your B you should have a B2187R bolt-in hub and a B2189R clamp.
I would be interested in the casting number of a round spoke wheel for an unstyled B which has 18 spokes. Other models had different number of spokes, depending on the year and number of spines on the axle - were you referring to models other than the unstyled B that have 18 spokes?
old
03-06-2008 17:20:53
Now I can not be 100% sure on this but from what I know ALL flat spoke wheels where steel one and round spoke where for the rubber tires
Dandy Don
03-06-2008 19:10:23
 Re: Round spoke wheels for John Deere B in reply to old, 03-06-2008 17:20:53
Old, I'm pretty sure these were never cut off 'cause the wheels didn't have tires on it when I got it and you can see the buttons (big round 'bout the size of a silver dollar) on the inside next to where the tube would be. Duane, I'll get the casting numbers off the wheels and email to you but it'll be a few days as I left the tractor at my buddy's farm in Pulaski 'til I can break it to my wife gently. The carb you did works perfect. Great job. The 36 B didn't have a mag or carb on it and I have two X mags. My friend has a 35 B that has a mag with an exposed coil wire. I hope I don't have to have one like it. I have you email address and I'll send you a note with casting numbers in a few days. I hope to trade one of the wheels for a mate to the other.The eighteen spoke wheels (round spoke) are on ebay now with one day til closing and are located in Elkhart Tx. Also what carb for 36 B DLTX #? Thanks guys. Don
Duane Larson
03-06-2008 19:41:21
 Re: Round spoke wheels for John Deere B in reply to Dandy Don, 03-06-2008 19:10:23
All I find are a pair of cutoffs with 38" rims welded on (10 spoke, 10 spline) and broken hubs. Do you have an ebay #?
Glad to hear the carb is doing fine..
old
03-06-2008 19:21:40
If its an all fuel it should be a DLTX-10 which can/will hurt if you buy one. I found that out on my 1935 JD-B and it cost me just under $500 before core return. As far as mag theres a few that will work just fine try this number for a mag. 417-358-7863. Ask for Jack thats where I got one for my B
