Converting a B to Electric
davebr
03-05-2008 20:01:35
Guys how hard is it to convert a 1950 B to Electric Start or can it be done?
James Tabor
03-06-2008 05:14:42
 Re: Converting a B to Electric in reply to davebr, 03-05-2008 20:01:35
I have a 1945 hand start and love it. No wires, voltage regulators or generators to mess with. As long as the mag and carb are adjusted properly it will start on the second or third spin. Many folks think that it is necessary to spin the fly wheel as fast and as hard as possible; this is not the case. Simply stand flat footed and turn, if everything is set to factory specs she will start, no problem.
davebr
03-06-2008 04:14:05
I thought it was a 50, I'll check when I get to work. I have nothing on it now. Just your dastardly
hand start, that will give you a heart attack trying to start it. I put a new carb on it.
MB deere
03-06-2008 15:52:48
 Re: Converting a B to Electric in reply to davebr, 03-06-2008 04:14:05
I'd give the mag a little tinder loving care. Clean points. Makes a big difference. Make sure it will spark about a 1/4'' spark. Then make sure timing is correct. If carb is right should start easy.
Duane Larson
03-05-2008 20:45:19
davebr,
Are you sure of the year? With the 1947 model year, all B's came with electrics to my knowledge. The difficulty depends a bit upon the year - '38-'40 are harder because of the slant dash used - 6 speed models would be easier.
buickanddeere
03-05-2008 20:24:43
Any electrics on the tractor now, Lights?
