4240 pto
Ts
03-05-2008 18:29:02
I have a jd 4240 with pto problems. The pto will not stop turning with no-load, and when you try to engage the handle on the dash, you push it up and it will not stay.
How do you go about trobleshooting to find the cause, where to start? Would love to use a shredder and post hole digger, but can't.. Thanks..Ts
Mike w J
03-06-2008 06:16:07
 Re: 4240 pto in reply to Ts, 03-05-2008 18:29:02
On thr quad transmision first check all external linkage . Then if you find nothing wrong You will most likely need part no R67981 that is a sub for R62042. This is in the pto valve on the side of the transmision it is a shift arm that is made out of puter and they bend over time . We have had to replace 2 on a 4440 but the last time the sub was a little heavier.
Ts
03-06-2008 04:57:18
Thanks for the replies, and the trans is a quadrange... Ts
Bob
03-05-2008 20:02:37
First, check for the linkage binding at the clevis where the rod attaches to the PTO clutch valve lever. (The pin rusts solid to the lever.)
mattd
03-05-2008 19:53:32
what transmission? if you have a powershift check behind the clutch valve housing for dirt build up behind the pto lever, i dont know how many pto clutches if have seen burnt up because of this. ok to hold the lever up a quad range uses a piston in valve housing and powershift uses a detent on the dash. as far as the pto not stopping we need to know what transmission you have. somthing that came to my mind while thinking about this is the lever could have come off of the linkage. under the front left of cab is where the linkage hooks to the lever for the pto valve. make sure this linkage is connected to an arm.
