J.D. 4450 P-quad-range
James A
03-05-2008 15:26:00
having trouble with P-shift part, it does'nt want to shift from 1 to 2 or 2 to 1 the same with 3 to 4 and back. When the engine R.P.M.s are up around 2000 it shifts just fine. I am thinking its a pump pressure problem. And if it is how much of a job is it to fix. If any one has had this problem or if someone can shine some light i could sure use the info. thanks.
mattd
03-05-2008 17:15:14
 Re: J.D. 4450 P-quad-range in reply to James A, 03-05-2008 15:26:00
is the clutch working properly? it uses the same pressure that the hi/lo uses. you could have a leak into the detented hi/lo valve, sealing rings could be leaking. left side behind battery is the pressure regualting valve housing. look for a port that says sys press. hook a gauge up here you should have 176-190. see what it does with the clutch engaged disengaged and with clutch depressed switch the hi/lo back and forth, it shouldnt change that much. you could also check lube pressure. on the left side on the corner of the transmission is the return oil manifold. it will have a big line going to the vertical filter. there will be another port to check lube pressure. see what it does while shifting and with clutch engaged and disengaged. i cant remember the spec off the top of my head but it should be higher than 30 psi. post back with results after you do these tests
powertech84
03-05-2008 15:55:55
what exactly is it doing?
