Best place to repair cracked head on unstyled A
Jason Mills
03-05-2008 06:47:03
I have a 37 A that has a crack leading into compression part from freezing. It is in the lower part of the head on the bottom most jacket. It is also cracked on outer jacket. I have another head that is also cracked between the two valves. Which head would make the better of the two to repair? Or would I just be better off to hard block the lower portion of the freeze cracked head? Tractor will not be worked and is not driven for extended periods of time. Mainly just shown and the occasional short parade. Thanks, Jason.
Mike M
03-05-2008 11:48:35
 Re: Best place to repair cracked head on unstyled A in reply to Jason Mills, 03-05-2008 06:47:03
You could have the one that is cracked between the valves pressure checked. I have had them show up cracked with a magnafluxer but tested ok with a pressure test. I have seen unstyled B heads being made reproduction now. I think on ebay ? they may also have them for A's. There was a place in Columbus Ohio called Columbus cold weld that fixed them and gave some kinda warranty too. But they weren't cheap either.
DGK
03-05-2008 09:50:41
Chapin Machine, Chapin Il. 217 472 3151
gpuller
03-05-2008 08:23:56
Midwest Cylinder Head in Nevada IA.
http://midwestcylinderhead.com/
