JD 290 2 row planter
BlueRiverHunter
03-04-2008 19:24:59
Looking for a little help so if someone has some information I would appreciate it. I purchased a JD 290 2 row planter, after I got it home I noticed that the mechanism that engages the fertilizer driveshaft was broken. The great thing is I located a new to me one on Ebay and purchased it. However now comes the part I need help on, are the gear splines heat seated on the end of the fertilizer drive shaft? I cannot find any set screws or pins that hold them in place.
long green line man
03-05-2008 17:35:55
 Re: JD 290 2 row planter in reply to BlueRiverHunter, 03-04-2008 19:24:59
My om. & pc shows groove pins (#34H-103H) holds bevel gear to each end of fert. drive shaft.
BlueRiverHunter
03-06-2008 17:59:04
 Re: JD 290 2 row planter in reply to long green line man, 03-05-2008 17:35:55
Thank you!!!! this really helps.
